Just to satisfy my own curiosity, when (mileage wise) did you folks start experiencing this idle problem? As for myself, I had trouble free operation for about 32,000 miles, of which 16,500 were driven after extensive modification to the heads, TB's, intake & exhaust manifold, cam, and ECU. etc...
I think if the Mod's were the culprit, they would have shown up much sooner than 16.5K miles. When you re-flash your ECU, does the idle straighten out for about 300 miles then start hanging?Mine does. After re-flashing, the idle will "step down" in about three seconds to the idle position regardless of car speed when decelerating and the clutch in. (This is how the car should behave) After a few hundred miles, the idle will begin to hang at about 1200 to 1500 RPM until the car is completely stopped. No difference with the clutch depressed or not at this point, and even then, it takes 15 or 20 seconds to settle out. The only other way to bring the idle down is to "lug" the motor down to idle. DRB shows all systems OK. yet obviously something is not! I've tried all the "fixes" I know. Any additional Viper Owner or tech experiences concerning this problem would be appreciated. Someone help us fix this problem PLEASE!!!
