Seat Belt Mounting Hole on Transmission Tunnel
dunce
Been looking for the bolt hole on the transmission tunnel for the "inside" part of a 5 point harness.....been pokin' around with a needle.......(I could have disassembled the entire interior in the amount of time I have been poking around....but then again when I go fishing......I know going to Safeway would be quicker and has a 100% sucess rate).....
......anyone have a photo with the carpet removed (I need a fish finder)???
z
GR8_ASP
I ended up taking the carpet off on the passengers side because I could not locate it. Had the seats out also. No pics though.
Flash1034
San Juan Capistrano, CA
z
Ironic that you posted this. I was just going to ask soemone to post the step by step instructions for the TeamTech 6 pt harness install on the SRT-10. Could someone please post it for fax me a copy of the install instructions? fax: 949 347-0109 or [email protected]
Please,
Flash
TBarrow
Cypress, Texas
MIne already had a bolt in it so an Ice Pick would not do it. I will try to get some measurements from the floor and the back of the car.
D
dunce
Hey...some measurement of where the center of the bolt is would be great. If you could measure from the rear floor "corner" going forward and then up. Thanks Mark
Mike Dolan
Northern California
First off, you won't find a hole as there is a bolt in the hole, feel for a bolt head. Also check straight up a couple inches above the seat mounting stud and that's where it'll be.
Regards,
Mike Dolan
tractor1996
