Secret coolant plug removal tool
95Viper
Phoenix
Here is the secret coolant plug removal tool! It's about a 2" long piece of 5/16" square stock. Find one in hardened steel if you can even if you have to buy a long one and cut it to length. I bought mine at a local old school hardware store and they had them in the pull out boxes with all the bolts and stuff. They had many different small lengths so I bought 3 for $1 each.
Insert in deep socket! I can't recall the size but it was a std size. Do not just put in shallow socket as my first one twisted in a shallow socket the darn coolant plug was so hard to get out. Hardened steel wouldn't have done that. If you don't have a deep socket, buy one for a few bucks, spray it a color so you'll always have it for this. I used this, an adapter to 1/2" size, a 10" long 1/2" extension to the rachet. This gave me perfect leverage to safely get out the plug without twisting.
Silver Snake
San Diego, CA
Yup, wish I would have known about these links before I flushed my cooling system. I could not find that tool to save my life. I ended up grinding down a 3/8" extention. Worked fine, but a lot of extra work.
Mark
AviP
New Canaan, CT
95Viper
Phoenix
Avi, I did search and I'm ticked if you actually find the old thread.
Johann
Sacramento, CA
Another "secret" plug removal tool is the kickdown band adjuster from any eighties or earlier Torqueflight transmission, it's a 1/2"-20 stud with a 5/16" square end; weld a nut on one end and you have a plug remover.
tractor1996
