RTScott
Several questions from a \"new\" 2002 RT10 owner in Maryland
Please excuse my ignorance, you've probably read these type questions before.
1. I am the 3rd owner, red with the Cognac interior package, 6,356 orig. miles. The previous owner may have traveled a gravel road a time or two, but I've discovered the smallest of pebbles lodged between the driver and passenger side doors and the front wheels. They are evident when you raise the hood, and are located on the flat between the fiberglass on the lower body panel and the sill corners. There are some pebbles under the fiberglass flat as well. I have removed the two bolts on either side to loosen the fiberglass/plastic and have vacuumed a few out, but want to know if anyone has any advice. I'd like to maintain this area pebble free.
2. Unless someone has a better idea I was going to ask the local after-market paint store to mix a batch of the 2002 red, as the local dealer advised that it has been discontinued.
Thanks in advance.
Thanks in advance.
