GTS21
Background--1996 GTS (#21), B&M Ripper Shifter.
I decided to reinstall the original factory shift knob, replacing the MGW knob that I've had for years. I followed the instructions in the how-to section. I lowered the boot, put a wrench on both the knob and the locking nut, loosened the nut, removed the old knob, WD-40d the replacement knob, screwed it on
as far as possible (as far as I could still keeping the shift pattern straight), and then tightenend the locking nut.
At some point in the middle of the above, I had a moment of sheer and utter PANIC when i thought that i was unscrewing the entire shift linkage!! Is that possible? I'm not sure if i was turning the locking nut only or the entire shaft of the shifter!! Can the shaft become unscrewed from its base? Can it be OVERTIGHTENED into its base?
The shifter and shift knob seem tight (don't feel loose) now, and the car is shifting okay--EXCEPT (and here's why i'm posting):
***There seems to be more noise coming from that general area now than there was before. I'm hearing more engine noice, more noise when shifting...mechanical sorts of noises...claking/clinking/cluncking...noises i don't remember hearing before!!
Could I have screwed something up? Maybe overtightenend something? Granted, I don't usually drive with the radio off, listening for noises from the shifter area, so maybe i'm imagining things. If the car is getting into gear, and the shift knob and shifter feel tight, is that a good sign? Should I have it checked out?
Any help would be appreciated. Thanks, Eric
