jmillsUT28
Needing to change my spark plugs before my dyno tune. Have some questions on which plug will work best for me. The car is a 2002 that has a built engine from Underground Racing with a paxton setup. Really do not know much about it has I bought it from a dealer and underground is not helping me with getting the info showing what they did to the engine. But they did say they did a full build on it. The plugs that are in it are the Bosch Platinum + 4 4428 with a heat range of 8. Not sure how long they have been in the car but they look really bad. The car runs like crap until you have driven it over 5 minutes. After talking to a few people and doing some searching on this site this is what I have found...
NGK R5671A-8 4554 Heat Range 8
NGK ZFR6F-11 4291 Heat Range 6
NGK BKR7E-11 4644 Heat Range 7
Wish I could give you more info about this engine but Underground is not helping me.
Which plug would you install in this setup? I might just buy a set of each as they are not expensive and see which works the best.
P.S. This is not a tracked car.
