Spark PLug problem
V10 MOJO
Youngstown, Ohio
decided to change plugs this morning and all is going well, until... cannot get the plug out which is closest to firewall on drivers side. i was easily able to get it unscrewed but cannot get it out of the "tube" it sets in? I was using needle nose pliers for the other plugs to extract them but i cant get the pliers in due to space limitations. any suggestions? im sitting here in the garage with a nine cylinder viper
Tiepilot
Lilburn, GA
A *** of duct tape on the end of a coathanger will grip it enough to pull it up so you can grab it with needle nose pliers.
Mike Brunton
N. Andover, MA
My spark plug socket has a rubber insert that grips the plug so when I finish unscrewing it, it just lifts right out.
I got it at Sears... it's a good investment (only a few bucks and you'll use it alot!)
99 R/T 10
Enterprise, AL USA
Get a set of long needle nose pliers from Harbor Frieght or any other tool store(these are about 3-4 inches longer than the norm), that is what I used.
Mike
tractor1996
