Throttle Bodies
Marc Lublin
Oyster Bay, NY, USA
Was wondering whose throttle bodies people are using. I know that they don't do much if anything on a stock motor but mine has high flow heads, intake, cam, ect. That being said, I believe the motor will benefit from a set of 70mm bodies. I am looking at the Accufab and wanted to know if anyone had experience with them or others and had any good input.
9 seconds
Texas
I've seen several Accufab 70mm out there. Contact Prashant. He might have a pair available.
LTHL VPR
Marc-
We played around with a few different sizes on the dyno. We found the 70mm more flow than necessary and caused a slight loss in power. I would recommend 65mm or 68mm instead. We will be finalizing our 65mm and 68mm throttle bodies in the next couple weeks. They are very trick looking and are a great compliment to the Viper engine compartment.
I'll keep you posted.
-Wayne (LTHL VPR)
rharon
