I use by 2003 Vert as an everyday rider. Getting close to the time where I will need to replace the tires. Running stock run flats now. I know everyone raves about the PS2 versus the run flat but is the performance boost worth the risk of being stranded?
Russell, you gotta believe this:
Your real and true danger is the 9+ year old runcraps. Not the flat-tire fear.
You can carry 2 cans of Fix-A-Flat in your trunk (truck-sized cans with the hoses.) Under $12. A plug kit under $10. You can carry a name-brand tire sealer-inflator kit, under $95. A bit more for Mopar. Many of USA and Chrysler's line, Jeeps, SRT-8s, Vipers, etc come with the latter. Even if you have a FAST leak, you can limp to safety and refill the tire several times with the compressor.
Buy a tire that improves your grip, braking, cornering, emergency transitions, watershed
selected for 99.99% of your driving, and not the .01% of what MIGHT happen. If you choose PS-2, I believe you will come back here and say: "AMAZING!! SHOULDA DONE THAT YEARS AGO"
JonB~~~~:<~
