crayne hurst
Hi,On my ford gts i can plug it in cell outlet. Can i do that on a new gen 4, if so any brands come to mind. Thanks, Crayne.
Maybe means the power outlet in the console compartment. That is where I plug mine in as it is a unswitched outlet.
I have 3 Black&Decker float chargers...Has a 1 amp and 2 amp switch plus you can connect it 3 ways..I use mine in the console outlet..Best money ever spent and I leave them on for 6+ months...Cost is about 21.00 at Walmart...Home depot...Kevin
On my Gen 4 I always keep the Deltran battery maintainer connected to the 12 v. plug in the center console. You can keep the window almost up to let the cord out. DONT use a trickle charger as you can over charge your battery if left on. The maintainer will bring it up to the proper voltage and then maintain that voltage. Google Deltran battery tender for the best price. They are not expensive but work great.Hi,On my ford gts i can plug it in cell outlet. Can i do that on a new gen 4, if so any brands come to mind. Thanks, Crayne.
