Two months of hot sweaty weekends & car is done. Finally snapped some pics.
PhoenixGTS
Phoenix Arizona
Monsoon finally let up and I got some pics. Let's see if I can remember all that I did in the past two months:
huge amount of cleaning underneath
brakes = e-bay drilled/slotted rotors, Porterfield R4S pads
Aldan coilover shocks w/300-500 springs = raised half inch over Eibachs
Roe facia ducting kit
Roe rear air box section with 3" outlets & new silicone tubes
painted windshield cowl piece to match body
repainted underside of facia & added Roe rubber bumpers
removed foglights and painted fog light covers to match body
Rand HID low beams
MGW round shift knob
powdercoat steel smooth tubes and PCM cover
vinyl graphics on wheels
vinyl windshield banner
I know the painted fog covers are blasphemous. I apologize if anyone is offended. At first I hated them but they are growing on me very quickly. I did the graphics because after two years of owning the car I was getting bored - and in five minutes I could peel them off if I want to give up on the rice boi look.
mad0953
Southern Oregon
Looks good. I am not a big graphics fan though. I like the painted light covers. Do you notice any difference in cooling with the Roe facia kit?
PhoenixGTS
PhoenixGTS
Phoenix Arizona
So far in the short 15 or so miles I have driven not one iota of difference. Have not been on any sustained freeway runs yet though. In-town only so far so not moving through the air very quickly. Nice kit though!
Mccarlin
Chicago, IL
Re: Two months of hot sweaty weekends & car is done. Finally snapped some p
Man you guys are going to make me paint my cowl i just know it :)
Looks nice. I dont care for the graphics on the wheels though. Who did the graphic on the windshield? I'd like the same thing but with a blue ACR instead of GTS :)
How are those ebay rotors too? any good?
Casey
Valparaiso, IN.
Looks pretty damn good! :2tu:
Now spend a few minutes and change your brake fluid! :D
I just wanted to say it before some tech. guru did! :D
Nadine UK GTS
Bath, Somerset, UK
Thanks for pics, well impressed with painted light covers...look fantastic, I'll be doing some for mine now. Only personal comment re grahics is I wouldn't have gone with the red color, stands out and looks too rice, otherwise graphics is good, but in your case, maybe nicer as is, if all in grey.
PhoenixGTS
PhoenixGTS
Phoenix Arizona
Motul 600 is your friend :)
Fairly fresh Motul in the car. Nice and light and clear when you look in the resevoir. For some reason it looks dark from the outside. I think it is the white plastic of the resevoir getting dingy.
Jim Wilson
Chandler, AZ, USA
Good catch!
I can personally attest that Michael's brake fluid is fresh, it's the reservoir that is discolored.
Car looks very clean, but I'd lose the graphics. How 'bout some photos of the super clean undercarriage?
PhoenixGTS
PhoenixGTS
Phoenix Arizona
The nice thing about both the fog covers and the graphics are that they are temporary. If you sell the car you could peel off the vinyl graphics and throw in some clear covers in 10 minutes. You are right that the idea with the small bit of orange (UK "red" as you call it :D ) was to introduce a little color to the car as it has no "color" anywhere. All silver, grey, black. The only shiney bits are the throttle bodies, radiator, lug nuts and center caps.
V10SpeedLuvr
Mine did the same thing. Drain the reservoir and put a cloth on the tip of a flathead screwdriver and you can rub most of the "dingyness" (old dried fluid) off from the sidewalls. It wont get it "good as new", but you will be able to tell a difference
my viper
enthusiast
Chicago
Looks nice :2tu: . Can you post a straight pic of the graphics on the windshield? I'm thinking of doing the same.
Shelby3
liu;g
I just ordered a new resevoir from Tator yesterday. He said there were only two left in the system. That leaves one.
XS TORQ
San Jose, CA., USA
looks like you had the valve covers and manifold painted or powdercoated also. Looks good!
PhoenixGTS
PhoenixGTS
Phoenix Arizona
So what happened to the old wheels?
My old HREs are refurbished and on Dimitrios' yellow car in NYC.
I previously powder coated the intake and valve covers in grey wrinkle but forgot to do the steel part of the smooth tubes so I did the smooth tubes and the PCM cover to match the older coating work.
Dang I need to clean up that TPS harness plug! :confused:
JUCD VPR
IMO your car looks Bada$$, BUT i don't really like the fog light covers, or the graphics on the wheels. BUT different strokes for different folks!:))
PhoenixGTS
PhoenixGTS
Phoenix Arizona
I am not a ballar with a lift like you Jim :D , and it is hard to take undercarriage shots on jack stands, but here is a shot of the rear Aldan with the two little sleeves they give you to fit the heim end in the stock shock mount. You can also see that I powder coated the the lower shock mount yokes silver after grinding off the casting flash and smoothing out the no longer needed spring tail catch and you can see the Belanger wide clamp connecting their side sill piece to their rear piece on their back-half exhaust system. 40mm Tom caliper also but you can't tell that from a picture!
P.S. That is an oil sling from something not a scratch on the body behind the door.
Casey
Valparaiso, IN.
Damn, that looks GOOD!! :headbang:
Did you ever change your brake fluid? :D
Jim Wilson
Chandler, AZ, USA
Looks great Michael! I did similar cleaning a while ago. When I had the motor out, I meticulously cleaned the engine compartment and polished everthing I could. Then a couple of weeks later, while driving, my upper radiator hose blew off. Needless to say it wasn't spotless anymore! :hitfan:
What the hecks a ballar? :confused:
Jim Wilson
Chandler, AZ, USA
Nevermind, I found it......
"A **** that has "made it" to the big time. Originally refered ball players that made it out of the streets to make millions as a pro ball player, but now is used to describe any **** that is living large."
http://www.urbandictionary.com/define.php?term=baller
You are one crazy *******! :D
Tom F&L GoR
Wappingers Falls
Actually, you can tell it's a 40mm due to the boring bar contacting the inside of the caliper casting support for the outer pad. I'm working on that, believe it or not...
How about some pictures of the Roe cooling system?
PhoenixGTS
PhoenixGTS
Phoenix Arizona
If Jim did not live so far away I drive to his house and put the car on the lift so I could snap a shot. It is pretty much impossible to take a pic of the Roe duct with the car only a foot off the ground on jack stands (even the pics in the Roe instructions ****) - but let me tell you, since I had the whole facia off and repainted after I cut the hole it looks darn good! I re-engineered the rear structural piece Roe gives you as I did not like their suggested install (at least what I could make of it from their instructions) and think my version turned out a lot cleaner. Their big panel that goes under the "hole" behind the radiator was sized and shaped perfectly. I will try and think of a way to get a picture because it does look nice.
P.S. The rough texture of the oil pan is like a grease stain magnet! :confused: I don't know what you have to do to get these pans REALLY clean and looking new.
PhoenixGTS
PhoenixGTS
Phoenix Arizona
The o-rings where the AC lines connect to the condensor failed (I understand this is a common problem on earlier cars) sometime back and made an oily mess on the whole driver's side of the engine bay, and then I had the lower rear corner of the passenger side valve cover gasket crack and seep so that made a bit of a mess in the tunnel, plus I spilled a little overflow of fluid out of the master cylinder resevoir when I pushed the caliper pistons back for the new brake pads. NO MORE! Of course now I do not want to drive it and get it dirty!
drviperdds
Orlando
how's the aldans treating you, i have just went through 2 sets of rear ones in the last month and a half and i have the 3rd set on my 2000 gts now, i'm keeping my fingers crossed. :crazy:
Inferno
I was going to pick up some aldan's, tell me more before I do.
PhoenixGTS
PhoenixGTS
Phoenix Arizona
They look good that is for sure, and the fitment is even better than the stock shocks (I did change so that I have 9" springs all around - that put all four spring perches right about in the middle of the adjustment so if you want to dump it, this would allow for about an inch less height than I am running). I wanted a few things and the Aldans were a good value to get them given I have a street-only car: softer springs, adjustable ride height, externally adjustable damping. Mission accomplished so far, but I will admit the damping adjustments do not have a huge difference and it seems to me I would not have enough damping on the rear if I had stiffer springs. Seems fine for my soft 500 pounders, but 650s??? It is still hot here so I have not done much driving. I see people all over the Gen III board talking bad about the Aldans, but not much for hard data other than some isolated comprehensive failures. My car is just for pimping and 0-100 mph runs so I bet they will be fine for me.
tractor1996
