Uneven brake ware...Is this normal??? (PICS)
2000GTS
Miami, FL
Just changed my front pads and rotors. When I took the old pads out I noticed the pads were worn very unevenly. The drive side pads had much more pad left compared to the passenger side. Also, on the passenger side, the outer pad was more worn then the inner.
Is this common? I would suspect not. The old pads were EBC Greens on stock rotors. The rotors were the originals from when the car was new. The car is a 2000 GTS w/ 45k miles.
The car always behaved normally when braking. Never pulled to one side or the other. The only thing I noticed was that the passenger side front wheelthrow more dust as opposed to the other three wheels.
In the pics below you can see the difference.
Passanger side
Drivers side
ViperJohn
Maryland
Car was either tracked or the previous owner always had a large passenger in the car.:omg:
C O D Y
Vancouver, WA
What color shade of white are the "VIPER" words on the calipers? Also, when was the last time the brake fluid was changed?
2000GTS
Miami, FL
Car was not tracked. Most of the time the passanger side was empty.
Both sides are the same shade of white. The brake fluid was changes about a year ago at Doug Levin's shop.
treed
Mason, Ohio
I agree with Chuck. Even if the car was tracked, the brake pads should wear the same on both sides of the car. . . I would rebuild both calipers to be on the safe side, and have baseline starting point to see if the problem continues.
