Weight lost question for 2001 GTS
YellowSnake
Chicago, IL
If you are trying to make your car lighter so it is faster, dont take things out, put things in. For example: Nitros.
You could have 3 fat ladies, 2 clowns, and some groceries in the car and with nitros you would still hit 10's all day in the 1/4.
SapphireGTS
Columbus Ohio
I beleive you are correct
SapphireGTS
Columbus Ohio
SlowCreamPuff
Bellevue, WA USA
Anyone knows how much stock 2001 GTS wheels weigh?
Besides HMS, any other choices for hood, etc?
More power is good, but lighter and more power is even better.
Martin D
Dunwoody, GA USA
Hey Slow,
I think you are going to find it difficult to significantly trim weight. A few pounds here and there, but that is about it.
How much are you looking to lose? (not you, your car)
So, what have you decided to create with this project?
Do tell!
Best Regards,
SlowCreamPuff
Bellevue, WA USA
Dion,
I know, too much cream.
Martin D,
Yes, it does seem like it will be hard to lose much weight.
I was hoping to trim maybe 200lbs?
The plan? Keeping it a secret for now.
SapphireGTS
Columbus Ohio
If you want to trim weight, how about ditching that 488 ci motor and gigantic wheels for something a little lighter. Like a TT v6 or nice aluminum V8 also add some magnezium wheels. Not to mention that pig of a rear end. Ditch that. Anyway 450 HP is pretty worthless for 488 ci. with the smaller motor you could cut the nose down quite a bit and shave off some lbs. Yank that tranny/dif for a transaxle. or you could buy a Z06 corvette and put twin turbos on it. Urr wait a min. Didnt you do that?
Seriously,
Id start with HMS Carbon Fibre hood. Get some magnesium wheels. A carbon fibre drive shaft.
Bob Woodhouse
Fort Worth, Tx.
Short of Mr. Schillinger most of your friends offered good entertainment. Is your goal of 200 lbs attainable for a street machine? Yes absolutely. Let's start with rotating mass and as the saying goes, 1 lb of rotating weight is worth 10 lbs of vehicle weight. Stock rims weigh 22 to 26 lbs. Aftermarkets small help but you can get a rim down to about 20 lbs before breakage starts. Race tires are several pounds lighter. An entire wheel and tire package is maybe 20 to 30 lbs. Not much savings here. Brakes, a good weight loss available, up to 50 lbs. Brakeman, Stop-Tech, Dilussi all have good systems that can reliably stop you with less rotating and unsprung mass. OK flywheel and clutch, Tilton, about 40 lbs. Or 17 lbs with al flywheel, the way to go for a drag racer. Hood by SVSi weighs 12 lbs for street, stock is 87 lbs plus lifting hardware. Doors from Autoform without windows, about 50 lbs each side. Remove the stock doors and store them. Doors are about $600 each. Now if you want glass, add back a few pounds. Not much savings to be had in the windshield but the rear glass can be turned to Lexan for about 25 lbs. Five Star makes these. Seats, you can save about 20 lbs each side with Kevlar seats. If you are still needing more we can find another 100 lbs without changing the looks. Nitrous, super neat stuff (some experience) is one dimensional vs. weight which when reduced improves acceleration, stopping and cornering, reduces vs increases stress on the vehicle. Choice depends on your intentions of use. May the force be with you
Makara
Hollywood, CA
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by YellowSnake:
<HR></BLOCKQUOTE>
Wow, sounds like a tight fit. I picked up two lovely ladies at one of my sunset blvd. hangouts on friday night and it was a tight squeeze to get them into the viper. God, I love this car!
SlowCreamPuff
Bellevue, WA USA
What are some sane and effective ways to make my 2001 GTS lighter? Obviously, sane is subjective but I would like to hear your input.
Are the stock seats heavy?
Lexan windows?
Thanks.
Y
YellowSnake
Chicago, IL
MAKARA-
Haha, I would agree, that would be a tight fit!
I recently also had a couple of hotties in the snake after a crazy night bar hopping. We got on the hightway at about 4am and hit 140mph. Needless to say, there was SOUP in the passanger seat from the excited females!
Drive it like its stolen!
Butch The Snake
Chicago
MAKARA-
<HR></BLOCKQUOTE>
JASON YOU WOULD PROBABLY BE BETTER OFF IF YOU WOULD STOP PICKING UP THOSE 15 YEAR OLD GIRLS AND SCARING THE PISS OUT OF THEM, THEN YOU WOULDN'T HAVE THAT SOUP PROBLEM ON YOUR SEAT.
Tom Friend
Kingston, WA USA
SlowCreamPuff told us-
15?? Isn't that illegal everywhere?
<HR></BLOCKQUOTE>
Not if you are a democrat.
Then it depends on your definition of the word "15"...
tractor1996
