Tom;
Thanks for the very interesting link.
The airflow was exactly what i was expecting, the front of the viper is slightly V shaped and obviously,fluid taking the path of least resistance ,the air on both side of the grill opening has no choice than go left and right.
BUT, the viper on the pictorial seems to have the fog light or a cover on so the airflow is backing-up in front of the fog light and slide to the side..
I think that the "problem" is not location but rather design.
If I wanted to use the fog lights as air duct, i woud put a 1/2 moon shaped shield,extending forward about 6" on the outside of each fog opening.
All the air that is now deflected to the side would be forced inside the air duct.
On one of my race cars (a 69 Mustang) the outside headlights are located on both side of the grille opening with the front of the car having a very prononced V shape and when I decided to use those headlamps opening for air ducts, without those shields I was getting very little airflow and brake fade because it was easier for the air to slide by the openings.
The shields made a huge difference.
Luc,
While the body shape is different, the pictorials (image 4) of the air flow direction would be similar. Notice the "arrows" are parallel to the body in the vicinity of the fog lamps rather than perpendicular. That would indicate a low pressure area.
Composite wing key to high-speed stability: COMPOSITESWORLD.COM#
