ViperRichRT10
Can anyone tell me what detonation sounds like? I have a Roe SC and a somewhat loud exhuast. What does it sound like from the drivers seat at wide open throttle????
Thanks,
Rich
Thanks,
Rich
Know that thing when you push the gas pedal down? it sounds like that...
think school bus going up-hill sounding like a bunch of marbles.
if you are worried about it, put in a few gallons of 100 octane and that should clear it right up. or we can take some timing back out...
JD
get it fixed. i couldnt get dyno time and my pistons went. i had detonation for most of the summer. now the motor is opened up and its costing me a bomb. get it tuned right!
it it part throttle or WOT that it happens at?
JD
Joe Dell's suggestion of running some 100 octane would be perfect in your situation. Run the tank down to almost empty and throw in 3-4 gallons of 100. If the noise goes away in the same conditions that is a real good indicator it was detonating. If not time to look for another cause.When I hammer the gas on the freeway, I hear some chattering noise. Sounds like detonation, but feels like it's coming from behind the car. Could it be something else? I only use premium gas.
Tony - go ahead and scare him... gheesh!
JD
When I had detonation it sounded like a tiny vibration noise from under the hood.
Look at your plugs. Detonation can show up as tiny little round specs on your plugs.
Dimitrios,
Does what I describe sound like what you were experiencing?
No clues?When I had detonation it sounded like a tiny vibration noise from under the hood.
I'm in ******-California... where do I get 100 octanes?
