Adam,there is a access panel i the center of the rear deck.You reach it by pulling the carpet back on the deck right behind the seats and you will find a plate with 4 rivets holding it i place.this will give you access to remove the fuel pump module.
The RT has a panel to remove the fuel tank.If you need to take the tank out of a GTS then you need to cut out the panel to remove.You don't need to take the tank out of a GTS to remove the fuel pump but you do on a RT/10.
