Jack the car up so that the front wheels are off the ground and the distance between the wheel wells will open up enought to get the brace out or in.
I thought you had a paxton. If you do....it doesn't go on I believe.
you might wanna install the paxton bar so you dont have to do it later. but i think it is easy (on top of the motor) so it wont be an issue.
half the motor comes apart to the paxton anyways...LOL
I do all of my own work after buying my cars. I am not the greatest at tuning and will eventually go to a Pro tuner (like DC Perf) once I'm finished.
The Paxton should come with a rough tune and the tune shouldn't matter until about 3,000rpm so you could drive it to DC Performance gently, and at low rpms - after you get it put together unless you're a long ways away. If the car doesn't run well enough then you have the tow option.
If you're not comfortable with it then tow it to DC Perf. They have a stellar reputation and will do a good job.
Ted
Ted
IMHO - you want to run the car with the new heads/cam prior to complicating ( sc) the equation. This way you can get a base line dyno pull before you add the sc. Then there is no finger pointing if the hp is not where you want it. What are you using for engine management?
I do have the split second but I might just do a SCT tune...but it's going to be between the two...which ever is more reliable....
