I have a suspect bad wire in the harness that connects to the Ignition Control Module(ICM), passenger side below PCM.
I know the pin outs and want to check 2 wires to see if there is a break at the harness or within 6 inches of it. I'm electrically challenged...what tool would I use? I could obviously insert a probe of some sort in the harness end but can you clamp onto the wire 6" up to test continuity or do you need to [******] or cut through the insulation into the wire?
