1TONY1
Can someone tell me if there is a top/bottom orientation or are they supposed to go in either way. No directions in the box.
I fitted mine the same way Tony has them![]()
Hey Mike, can you or Tony do mine next weekend? I will supply beer...![]()
I don't recall what rationale I used, if any, to orient the mounts when I installed them. I seem to recall that the knubs on the mounts could be ground down if needed. I unbolted my mounts recently so I could raise the engine/swap out the cam. They seem fine. Best bet is to ask Mark at Woodhouse if the orientation matters.
Replacing Engine/Transmission Mounts Part II – When to Replace?
Replacing Engine/Transmission Mounts Part III – Replacing Engine Mounts
PIA Changing Engine Mounts How To by Mike
- Tony
Can only go in one way. Short stud into frame long one into bracket, flat side towards the ground.![]()
It will take more than beer...................
Real PITA, but if you can get a spot for Tony's place, I'll come up and help.
You don't eeeeeeven know the whole story
Now.....I am needing some lawn mower blades![]()
Mark, does it really matter?
Actually Mark they can go in more than one way. I recall being able to orient either flat side facing down... Studs up or down, etc. You also once posted that the studs could be ground down to make them fit: http://forums.viperclub.org/srt10-s...put-geniii-diy-motor-trans-mount-install.html
My car, it did.....like Tony said, you don't want to know the WHOLE story![]()
I'm beginning to wonder if that's what happened to me!?!
I had a Viper Tech install the Woodhouse hi-durometer engine and tranny mounts, and now my car vibrates so bad, I can't get any usable video, even with a stabilized camera and solid mounts. I mean, I swear that I can feel every single combustion stroke. I'm ready to rip them out and change to something else, it's so bad.
Could this be from incorrect mounting, or is this what I should have expected?
The alignment studs can get hard to get into the frame cradle so you can shave one off. The short stud if facing up will generally not work on the bracket although I have seen pictures on here that did.
