SmokinViperGTS
I just checked, and I've got over 3,000 miles since changing the mounts, and it's still a problem. If you click on this link to a recent auto-cross, you can see the vibration both when I'm idling at a stop in the start box, and especially when I let out the clutch or accelerate hard. The camera is an optically stabilized HD video cam ($$$) mounted on a steel bar with a 6" suction cup and a 34-lbs support rating. It's fair to say that it is accurately tracking the car body vibration. Sorry for the long (5 minute?) download time - we're still working on a better solution. If you have any trouble playing it, try using the VLC player - it's fast, lightweight, and plays everything.
I also used to to miss the 3-4 upshift occasionally. When I changed out the engine & tranny mounts, I also changed the shift knob to a MGW short knob, and the shifter mechanism to a B&M, based on the positive feedback I had gotten. Now my 3-4 upshifts are flawless - haven't missed one. But I'm missing the 4-3 downshifts instead. The B&M shifter has a much different feel. I've determined that this is simply an operator-error, focus issue - not the hardware.
So, is this normal vibration for these high-durometer mounts, or do I likely have an install problem? If this is normal, is there an alternative that is somewhere between the stock mounts and these, that will alleviate most of this vibration? I would happily switch to get rid of it.
Thanks,
Steve
Thanks,
Steve
