dipapa
Thanks allot Todd @ A&C Performance for working with me getting the right mods and dialing in that VEC3 nicely. took some good work and we reached my goal of at least 700rwhp.
Here is the Dyno Graph
a lot of torque at 2500 there. very nice. good luck and be safe
those gears are gonna force you to shift more often id think......
whats it doing at high rpm's ???
I never said the car was bumpy... Their is a bit of bucking engaging clutch in first and it feels great. The throttle response is so sensitive and instant one small tap on the throttle with that first gear ratio seriously lunges the car forward. The part throttle tuning, aggresove timing and tps adjustment made the throttle response absolutely exceptional! I'm running a/f at 11.8-12 wot across the rpm's.
I do not have the gen3 Paxton S/C kit as distributed by Paxton. We upgaded many components that needed to be for this power keeping intake temp low, fumes out ( not smog legit) clean air in and then it's mostly all in the tuning. Excellent Forced induction tuning makes all the diference in the world. We went aggresove on timing but the motor liked it. from a few authorities, tuners I know, on a dyno jet this car will make another 3-4% higher numbers.
I'd be happy to jump in. Most Gen3's on my Dyno Dymanics dyno run anywhere from 650-675 rwhp with about 600-620 rwtq with the split second box headers and exhaust. This is with the stock paxton tune in the split second and a clean a/f of about 11.4-11.9 out the tailpipe.
On 90% of our cars unless requested otherwise by our customers, we like to weld in bungs on the header to measure before the cat. On our dyno, we've seen anywhere from .4-.6 change before and after the cat.
The split second leaves ALOT of power on the table. It's designed to work on EVERY car so it's extremely safe. I know most tuners use the bigger FMU washer to help accomplish the safety factor.
We actually, just for comparison, had a customer make 558 rwhp on our dyno on his 2008 and then go to another dyno (dyno jet) and make 565rwhp. Possibly weather conditions, oil temps lower, etc but runs still very similiar.
Our dyno seems very "real world" not exaggerated.
I've had cars with Paxtons, headers, exhaust, upgraded intercooler, split second and other tuners tunes come to my shop and only show 670-675 with 635 or so tq.
Dimitri's car has countless hours of part throttle timing changes, driveability in even the oddest of conditions, full pulls and part runs on the dyno emphasizing on particular rpms that he spends the most time in, in addition to some various changes that we dont include in our average builds.
This particular car drives like stock. if you hold it in first gear it may experience a slight "viper surge" that most stock vipers have, but nothing i've even noticed. It has a slightly different merge collector than most headers, and the car has incredible leakdown numbers. I usually see 700ish on my dyno give or take 15rwhp with torque between 650-700 when using the Vec. I wont give exact specifics as to what timing curve this car has, but will say this car will make over 700 rwhp on a bad day, shows no signs of knock and the plugs show no signs of detonation.
In addition, I'd say anybody could get in this car that owns a similiar setup and honestly say if feels unusually strong.
I wouldn't promise 733rwhp to anybody running a stock bottom end. BUT we did accomplish it with this car. I will say the timing is aggressive, but this particular engine seems to like it, and dimitri was there on the last tuning session after we did the breather system and some other minor tweaks. I do thorough checks to assure a sound motor before even pushing the envelopes. We all know how weak the gen3 pistons are.
Dimitri has some "unique mods to his headers, exhaust, sensors (yes sensors) and it has all worked amazing.
This is the highest rwhp stock motored gen3 paxton car that has left our shop. Not everybody will achieve these numbers, but we can gaurantee a 690-700rwhp paxton setup, with 650-700rwtq, on straight 91 octane fuel when we pick the parts to be used.
Todd
Air fuel on this car tapers from mid to low 12's coming up on 4krpm then from 11.9-12.1 through redline.
and also Bobpantax,
as far as what your stating with the stock internals. Your 100% right. Dodge didn't build this engine, 2003-2006 for even any type of forced induction. ****ty rods, even ****tier pistons, low tension oil rings, and other internals leaving much to be desired in my opinion. There's much room for improvement. EVEN externally to assure these parts have a chance at lasting with these types of cylinder temps and pressures.
They do make good power and the slightest unsafe condition can be horrific. Depending on the customer and their requests, really depends on how far I will push the components.
Hi. I am not trying to argue with you. If the 733 RWHP number is correct, it cannot be safe based on stock internals. There is not 323 HP of extra tolerance built into the stock engine. I researched the tolerance issue before modding my car. My research included a talk with a retired person from the SRT staff. But, don't go by what I say. I suggest that you give some of our site sponsor tuners a call. I know of two that have installed over 100 paxton kits. I am only trying to help you prevent a future problem. With that, I wish you the best of luck and good times with your Viper.
Dyno's are for tuning, not for racing. You go to a drag strip for that. Take the car to the track and that will answer if he's making the power. I hate dyno's.
