jcaspar1
I am getting ready for a day at Laguna Seca
Lastly, I am still not clear on which fluid I should use! I plan on only doing 3-4 light track events a year and would prefer to nothave to bleed more than every 6 months. Any advice would be appreciated. Thanks.
soon and am putting in 5 points and a fire extinguisher. Also am thinking it might be a good time to bleed/flush my brake system (97 GTS, original fluid). I have read the posts here and my shop manual and just want to make sure I have got the procedue right. I understand that I should start by draining and refilling the master cylinder with fresh fluid. Start with the most distant caliper (RR), bleed the rears once, the fronts inside/outside/inside. I don't have a pressure bleeder so will be doing this with a helper. About 5 bleed cycles per bleeder, till fluid is clear using clear hose to a container filled with clean clean fluid.Lastly, I am still not clear on which fluid I should use! I plan on only doing 3-4 light track events a year and would prefer to nothave to bleed more than every 6 months. Any advice would be appreciated. Thanks.
