Car is Tickin and Idles Rough
Schulmann
Canada
I am really sorry for you Dimitrios.
Dimitrios, your case makes me remember a friend who had the SAME trouble. I do remember that in NJ your viper was already smoking while accelerating (too rich) and while breaking (blow by). We even had a look on that heavily modified yellow Viper to check his crankcase ventillation.
Low octane fuel (91 oct) + Blow by (oil in intake) + carbon fouled cylinders + summer temperature + high RPM (above 5000rpm) => 100% chance of dead for the engin.
The problem with the blow by is that the oil in the intake dramatically reduces the Fuel octane level. For instance even if you use 93oct fuel, the oil will drop the octane level to 90 !!! It happens so suddenly that you have no time to lift your feet from the accelerator and you engin is dead.
Unfortunately when all this happens there is nothing to do except to fix the engin and LEARN. Make some overtime at work and have your engin rebuilt: Forged pistons and blue printed engin. Stay away from modified cams.
Another note: My viper was not the most powerfull on that hot spring day but was the most reliable.
Cape Coral, FL
Broken rings? I am assuming you mean compression rings and not landrings? If he cracked rings, chances are he had inaudible detonation for quite a while... compression rings are really just springs, and when overheated from detonation, lose their heat-treat and become brittle, and often lose their "spring" as well, taking on the size of the cylinder and allowing blow-by.
D
Dimitrios
Queens, New York
ok just ordered diamond pistons, 10lbs pulley, idle pulley, Roe Racing valve cover breather(Roe's version of a catch can)and smaller belt from Sean Roe at roeracing.com. Chuck Tator is also installing a 96 mopar cam which Sean also recommends. ROE said it should be at the 700RWHP without the ported heads. veryone here has been a great help and thank yo guys so much. I cant wait!!!! I'll keep you guys posted. :headbang:
plumcrazy
ALL OVER
way to go D.
how long is it gonna take tator?
is he supplying you with deviled eggs thru the process ? ? ?
D
Dimitrios
Queens, New York
UPDATE: chuck tator took the motor apart and found 5 cracked pistons. he said that this will go in his record book for most pistons broken. anyways i ordered diamond forged pistons, 10lb pulley, 708 mopar cam and roe cylinder heads. roe said car should be at 700rwhp with this set up. cant wait to get it in 2 weeks.
ACR steve
NY,Rockland
maybe if you stop babying your it would not be broken :) :) Damn you kicked my ass with 5 broken pistons, now you will have to give me a couple of car lenghts if you ever want to line up with me again or I may sick MAD DOG BIRD on you
ACR steve
NY,Rockland
maybe if you stop babying your it would not be broken :) :) Damn you kicked my ass with 5 broken pistons, now you will have to give me a couple of car lengths if you ever want to line up with me again or I may sick MAD DOG BIRD on you
D
Dimitrios
Queens, New York
ha yeah steve 5 pistons..i knew there was something wrong. anyway im suppose to pick it up the day of tators tech session and drive back with you guys. i cant wait to feel 700rwhp. i thought 550was alot...
Viper Wizard
South Salem, NY USA
I'm hoping it will be done by then? You are going to have to do a break-in on a new motor!! You will not feel that 700HP till you do a SLOW 1000 miles first! Sorry :(
v10kingsnake
south jersey
hey D, if thats the case, you wanna race that day when we pick up our cars from tators. figure itis my only chance to embarrass a monster like yours is during the break-in. lol. can't wait to see your ride in person. bet you can't either. :2tu:
D
Dimitrios
Queens, New York
so seen my car today after 7 long weeks and chuck gave me the ok to started it up. it sounded ridiculous. the rumble and sound of the cam was awesome. needs minor tuning and road testing before i pick her up. will get dyno numbers shortly.
tractor1996
