There is a company that makes precut clear film for Vipers. The company is Invisible Mask and the film is very easy to install if you follow the instructions carefully. Using a water and rubbing alcohol wetting solution allows easy placement of the film such that it can be slid into place on the car. It is particularly easy on the relatively flat surfaces like the side sills, hood, and fenders. The worse part was of course the front grill which takes more patience but the pieces are also smaller which helps a bit. Cost to do my ACR was about $400.
PAVenomRT/10
