tzoid
My info from Dana and Unitrax is that Dana markets a Dana 44 and a Dana Super 44 gear set. The standard Dana 44 gear set in the 3.55 ratio is actually manufactured for Jeeps. It's the exact same dimensional size as the 3.07 and will therefore fit in the Viper. Dana will not "officially" recommend anything other than the 3.07 for the Viper because that is what they build for the Dodge Division of Chrysler Corp. for the Viper. Unitrax, whose name and knowledge of the product is well known and documented, as I remember when I had them do mine, does not recommend the Dana 44 Jeep gear set since the torque of the Viper is roughly twice the numbers created by the Jeep. They want you to use the Dana Super 44 gear set, which either has a higher strength alloy steel in the gears or maybe hardened to a higher spec, whatever! The price differential is only slightly higher than the standard 44's (guessing about 20%), therefore it sounded like a no-brainer to go with the more expensive gears. I'm sure there's no problem with the Jeep 3.55's....unless they fail. Not worth the gamble to me for $50-75 in price difference.
