PhoenixGTS
Well funny in a sad way. Ambients cooled, my Kumho V700s got a bit hard, I wheel hopped the car hard a couple of times, and the driver's side rear Aldan started leaking again. Today I took them off and shipped back to Aldan (who has great customer service and rebuilds them whenever they blow up). When I was backing off the spring perch ring on the driver's side to relieve the spring pressure before popping the top mount out, the two parts of the shock body started unscrewing. Apparently, the last time the shock was rebuilt, they did not tighten the two separate parts of the shock body with sufficient torque. I used a chisel and hammer to move the perch ring until it got loose enough to use the spanner. Then it tightened up again. Went back in forth ths way, I thought I had it under control, then bam the seal between the two parts of the shock body broke loose and shock oil started squirting out across the garage. The shock had been leaking out of the shaft seal, but there was still a lot of oil and all the nitrogen pressure was left. It was like I was performing heart surgery and I nicked the aorta. Squirted about 10-12 feet. It squirted for a good 30 seconds. One of those times when there is nothing like an epoxy coating on the garage floor. In hindsight it was pretty funny. Tomorrow I'll slide under the car and see if the wheel hopping injured any half-shaft universal joints. I guess they call this a hobby.
