Andrew/USPWR, Never to late.
Jdoc, so I'f I understand you correctly, you are going to be able to keep your ramps in the horizontal position when putting the other car underneath? That's ideal! I couldn't do that cause when my lift lowers, the ramps would extend out beyond the garage door. Then I'd have to notch out the garage door and I wasn't doing that.
I figure my Viper will be up top over the winter and my truck under. The ramps will be there in the up-vertical position all season and I just get into the truck and go.
So you ended up cutting the cross tube supports for wheel clearance? I'm sure it's okay, I would think they over-engineer these things anyway.
Nice to be able to modify these things ourselves.
Andrew
