CROM
So I am drving around today, I take a 75 degree sloping turn at about 60 in 2nd and then I hear a *pop* followed by a *clank* followed by the sound of something metal banging around inside something else metal. Sounded like something metal broke into pieces and was banging around. Noise goes away, I think that "maybe" my PS cap had come off and had kicked around in the engine bay. I pull over, everything seems normal. No odd noises, PS cap is fine. No leaks. So I continue to my friends house. I pull up to his driveway he opens the garage door and I think I hear a wierd noise and dismiss it for the garage door noise. I shut car off. Well we go to leave and I turn the car on and now I have a god awful noise coming from the middle of the car. Oil pressure is fine. No leaks. Nothing, just this horrible noise that sounds like something spinning and grinding against metal. I drive the car around the block, no tranny noises when shifting, all gears work just fine. Clutch is fine. But this noise still persists. So I have it towed 15 miles back to my house and the car sits.
SO, what the heck is wrong. This is what I am thinking. One of the flywheel bolts came loose or some how sheered off, and is now sitting inside the housing jammed somewhere and the flywheel is rubbing against it. Any other thoughts? This does not sound like it is coming from the engine. It is RPM sensitive sort of. The sound pulses a little when I push the clutch in and out. The sound also goes away if the car sits and cools down. Only to start making noise again after the car runs for about 30 seconds.
This noise is very LOUD and you can almost feel it.
HELP!!!
HELP!!!
