Ivory
My 93rt 10 (59K) has been problem free until this summer? I had the dealer flush the cooling system as normal maintenance. After the flush the car ran hot. Ok, back to the dealer for burping. After a 5k road trip the heater core started leaking inside the car which emitted an antifreeze smell in the car and leaking antifreeze at inside the engine compartment near the rear #10 cylinder. The leaking antifreeze was being burned off the engine which made a nice white smoke plume! Ok back to the dealer. The dealer replaced the thermostat, thermostat gaskets, intake manifold gaskets, the heater core, all heater hoses and all lower gaskets (1,010.00). Ok, picked the car up again. Noticed the car was still burning off antifreeze at the rear near the heater (#10 cylinder). Back to the dealer, was told that leaky hose clamp everything tightend and ok. Ok, on Friday evening, picked her up and drove 150 miles and noticed antifreeze smell inside the car and smoke coming from beneath the hood. Burning off leaky antifreeze again near the rear of the block near the heater core. Car is not running hot, but definitely leaking antifreeze! It appears to leak more when driven hard! My 5 star dealer is telling me to take it somewhere else and get a second opinion because it may be a head gasket problem?
First of all does anyone have a clue of what could be causing this. And also, has anyone had Roanoke work on their car and what has the service been like? I'm currently going to a dealer in Southern Wisconsin (Sauk City).
Any advice would be helpful.
Thanks.
Thanks.
