ViperSmith
“@RalphGilles: “@Kenric10: have you thought about forced induction on Gen 5?” let's just say we made it a perfect canvas ; )”
Bolt on from Mopar,
Bolt on from Mopar,
Great ! In the second video Ralph says that they will bring back 3 cars to LS with the mags people and have their own Domenic drive it against Randy Pobst.
Also mentionned that they will go back to Nurburgring in the Spring
Then he said both ACR and convertible will come in about 2 years
Lots of good news and faith in the Gen V !
A lot of info straight from Ralph's mouth in that 2nd video. Although I agree with bushido that I have to see it to believe it, I'm encouraged. Ralph also said that, with the right driver, the Viper is faster than the ZR1 at any track. The Viper is not as easy to drive at its limits, but its limits are higher than the ZR1's. I hope this true. I still think we need at very least a tire swap, I wish Michellin made the Pilot Sport Cups in the Gen V size. We shall see how Domenic does, this has turned into quite a rivalry.
We need to be thankful the ZR1 exists... just as Chevy is thankful the Viper exists.
Another tidbit that did not make it onto the video. There was a brief Q&A after Ralph's remarks. The new ACR will produce 1500 pounds of down force instead of 1000. I would not expect a MOPAR supercharger kit for the Gen V. Among other issues are what to do with the X brace. The car can run in a straight line without it but would not do as well on a road course. Perhaps someone will fabricate a square brace. If I had to bet on it, I would guess that Arrington and Arrow must be at least thinking about a supercharger kit by now. Arrington now has supercharger kits for the 392 SRT8 engine that utilize somewhat recalibrated 6.1 liter engine controllers. Pretty clever of them to figure that out. But a controller for the Gen V engine, even with open code, will require a very high skill set to recalibrate to allow a supercharger kit on the Gen V motor. It will happen but not quickly.
it would not surprise me if ralph has something up his sleeve like boost.
Plum, didn't I say this in another post!!! I must have a crystal ball!!! LOL. The X Brace and the Hood design will be easy to work w/a Roots type SC. It's perfect for a good washing machine!!!
Drop that compression, strengthen the chassis in other areas and PUT IT ON!!!! YES!!!!
If they do put a supercharger on the Viper it will definitely be a centrifugal. You can keep the X brace and find a simpler solution for mounting and cooling. Using a roots style would be like trying to stuff 10 lbs of crap into a 5 lb bag.
You could offer a special hood with enough clearance for a supercharger and a different x-brace, and the style wizards at SRT could make the hood look downright sinister. The x-brace may not be as ideal of a shape as the existing one, but it could be carbon fiber to avoid a weight penalty and to match its current stiffness.
Big cube engines like the Viper can make gobs of power when supercharged, without undue stress. Supercharger cams reduce overlap to maintain cylinder pressure, and as a result can be very emissions-friendly. We could see a supercharged ACR that could take anything on the planet, and it really wouldn't be that hard to engineer. The challenges would include enough cooling to avoid heat soak, and beefing up the rest of the drivetrain to handle the added torque. That would maimtain the Viper's legendary supercar status. Although I prefer normally aspirated, a supercharger may be a good tradeoff to take on anything a C7 Corvette could throw at it.
Maybe all we need in an ACR are better brakes, tires, downforce and suspension tuning, but a supercharger could pay big dividends and keep the Viper as King of the Ring for years to come.
How come he isn't addressing the brakes? Literally every test has complained about them.
