No Mr Hemi, I did not do that. Here is my problem.
On a cold start almost ever since I got the car, She will start fine, for about 2-3 minutes, and when I pull out or wait longer than 2-3 minutes, I will get hesitation, as in, when I step on the throttle to go, the car will buck and it ****** me off. It does this until I step on it good and go pretty fast, then it goes away until I turn the car off, let her sit for a few minutes, and the process begins again. Also, if I start her, and just let her sit, she wants to stall if I don't "clear her throat" by going about 30-40 for a few seconds. Today when she did it, I had her out of gear and stepped on the throttle lightly. With my foot not moving, the rpms would fluctuate about 1000rpm up and down.
I tried a lot of things to fix this. Any help would be appreciated. It has to be a sensor, but I dunno, I feel i replaced them all, O2's, MAP, Intake, New Plugs, New Wires, Unplugged battery.
Maybe it's something in the ignition because when I first noticed the problem, I was at the McDonalds drive through in March I believe, and my engine light came on, and right then it started to do it. The codes were high volts in the o2 sensor and ignition misfire. I did replace the O2's with Bosch plugs, and I did nothing for the misfire?
Help me please!
