The 1/2 the displacement post by Blwn isn't quite 100% accurate.
If you doubt me, just look at the units used on production vehicles, Magnuson, Whipple and Kenne Bell kits.
I agree, the bigger the better, but 1/2 the displacement is not normal.
These are four stroke engines. The engine only moves 1/2 the total displacement per revolution, so it doesn't take a 4L blower to maintain efficiency on an 8L engine operating at low boost and under 6,000 RPM.
Yes, the G1 and G2 kit is using the 2.4L. It will push 12 psi on that application, but gets real hot. 8psi is a great place for it to run on a Viper.
Ok, onto release dates....
Here's my dilemma; when my day starts, I have about four things on my “to do” list. Working on the Gen3 car kit is usually #4. As I'm doing the other things, a VEC2 comes in for an update, I get a phone call, someone stops by and suddenly, it's noon. After lunch, the same routine starts and I get maybe an hour on the car kit, which is what happened today.
Trust me, it makes me sick to my stomach how long I've been working on this and how long other people have waited. If you feel you have to do something to the car and don't want to put a Paxton on, consider an aluminum flywheel and the VEC3, both of which will really wake the car up in terms of throttle response.
Since there are a lot of very experienced business owners on here, what do you guys do to keep from getting stuck in this daily rut? I could use a suggestion because I really want to get this finished.
For power, on our totally stock car, including cats, we picked up about 130 RWHP with 5.5psi. The exhaust is restricting power at this point, but I'm not ready to put an exhaust on the car yet. My main issue is getting everything under the hood and into the blower. The really hard work is done. Now it's just the piddly time consuming, trying to figure out the best method, type of work.
If you guys want me to set a "do or die" timeline, I'll try. Maybe I can justify not taking calls if I have a timeline that I must meet.
Regards,
Sean
