Just curious how much spray my creampuff can take and for how long before blowing the motor? Aslo what is the propane setup exactly? Is it supposed to be safer?? I'm considering doing it, only if I can have a stealth install
I would love to do a stage III setup but 20k doesnt grow on treesjust give jason heffner a call, then you should be set....
My NX kit will be here tomorrow. Installing this weekend. Will let you know Monday weather I still have a motor or not. I figure if you ruin your engine, that gives you a good excuse to replace it with something better.
What size shot you going to do?
I guess you are doing a wet shot I assume??? I'm really considering this route as well, cause I dont need the headache of filling 2 bottles. Anyone know if the 10 or 15lbs bottle will fit where spare sits? Can it be covered by a trunk matt??What size shot you going to do?
100 to start. Its easily changeable up to, i think, 300. I am new with Nos so wanted so see how well I liked it before I went crazy with it. It was $1000. Pretty hard to resist.
I had a 200 shot, and I trapped in the mid 130's in my R/T. It did a little over 600 at the wheels, but I blew the motor sky high. Just be careful and take all the proper safety precautions and you'll be fine. I'd definitely do a window switch, full throttle switch, fuel pressure safety switch, etc. All three of these only cost 3 or 4 hundred bucks.
I'm thinking you had the wet kit I asume, cause no way would anyone spray a 200 dry shot Hmm never heard of the fuel pressure safety switch before? the other two I had before with my old setup in the vette, and was going to do them again Btw the motor you blew up, was that with cast pistons? Thanx.I had a 200 shot, and I trapped in the mid 130's in my R/T. It did a little over 600 at the wheels, but I blew the motor sky high. Just be careful and take all the proper safety precautions and you'll be fine. I'd definitely do a window switch, full throttle switch, fuel pressure safety switch, etc. All three of these only cost 3 or 4 hundred bucks.
hey moundir just answered your vec1 ? i run the btr n20 propane gas set-up.i have dynoed @ 655 rwhp and over 900 rwtq. i have gone thru at least 10-15 15lb. bottles in my 01.
