Here is an example of an inspection I just got from magoos.net As you can see it's not a viper tech inspection but for $149 is not bad either and I just ordered this last night. So if your gonna spend that kind of money on a car then a little more reassurance could be all you need but NOTHING IS FOOLPROOF when it come to cars.
Magoo's AUTOMOTIVE PRE-INSPECTION Date Inspected 8/30/2006
Assignment # 200608291949W Company Magoo's Pre-Purchase Inspections
Contract # 08291949W Customer
Year 1998 Make Dodge Model Viper
Verified Full VIN 1B3ER69E6WV400168 Verified Odometer 15700
EngineSize 8.0 Manual Transmission
OK Proble Inspect The Following Comments
Found
Road Comment Vehicle is showroom condition with some modifications done by Valawa Racing in San Jose by the original owner Ted
OK Engine Starting / Cranking / Idle engine starts and runs good. The inspector was not able to take on highway at cruising speeds
and it has no insurance. Drove only in driveway, turns, forward and reverse etc.
OK Engine Operation
OK Transmission shifts good
OK Suspension / Ride
OK Brakes good
Initial Comment: all accessories operate properly
OK Wipers / Washers
OK Clock / Radio / Horn / Cruise
OK Power Antenna / Digital Dash
OK Switches (Windows, Locks, Seats) Windows are tinted.
OK A/C / Heater / Defroster / Frt-Rr
OK Lights (Interior, Exterior)
OK Parking Brake
OK Interior / Seats / Carpet / Dash
OK Body Inspection Showroom condition
Under The Hood Comment: vehicle parked in garage with white floor and not a drop of oil or fluid of any kind underneath vehicle. All fluids are
full and good.
OK Emission System
OK Valve Covers / Seals / Gaskets
OK Belt / Hose/ Clamp / Vacuum Line
OK Air Filter
OK Radiator / Cap
OK Elecric Fan / Clutch Fan
OK A/C Compressor / A/C Clutch
OK Evap / Condens / Dryr / A/C Hoses
OK P/S Pump / P/S Gear / P/S Hoses
OK Battery / Alternator
OK Engine Oil
OK Engine Coolant
OK Transmission Fluid
OK Brake Fluid / Power Steering Fluid
Under The Vehicle (NOT on Lift) Comment Headers and exhaust system are aftermarket. Vehicle has duct air cooler for the brake
system., 3.54 ring and pinion installed in rear end, (gear change) B&M short throw shifter.
OK Engine / Transmission / aftermarket modifications in engine Roller rockers, aluminum
Differential flywheel, baffled oil pan, oversized throttle body.
OK Muffler / Tail Pipe
OK Catalytic Converter
OK Joints / Tie Rods / Shocks / Bushs
OK Frame / Undercarriage
OK Wheel Brgs / Axle Seals, C/V Boots
OK Tires / Wheels
OK Brake Calipers / Wheel Cyls / Lines
This is NOT a safety Inspection. This is a visual inspection of the vehicle and systems therein and is in no way to be relied upon to determine the safeness of this
vehicle. This inspection and the opinions expressed are exactly that, opinions. Many parts perform perfectly up until the moment of failure. Failure may occur
suddenly and without any prior warning. Due to the cursory nature of the inspection, the location, the constraints, and the lack of diagnostic tools, the inspector,
and or Magoo's Automotive Consultants cannot accept liability for failures or injuries which may occur after the inspection is completed.
ms
Test May.
Inspection
Cntrl
