I've had a through the glass antenna and a Wilson 5000 (very highly regarded antenna by CB'ers) mounted on a work pickup so we could communicate with our big rig delivery drivers on jobsites and or approaching jobsites.
I had an A/B switch set up so I could remove the Wilson when the big bosses were in town (they were weird when it came to accessories on sales trucks) and used the little Walmart $15.00 through the glass antenna if I needed it since you could barely see it attached to the rear window.
In multiple tests with known ranges, I honestly could not tell a difference when I'd experiment by going A or B on the selector. CB's are so low powered, that if you get anything over 4 miles or so in real urban settings, you'd be lucky. I'd have no problem using a through the glass antenna on my Viper.
I know that the wavelength and ground plane equations are supposed to matter, but on a 4 watt CB for communicating in a 3 mile radius, it just doesn't seem to matter in the real world. If you were to pump up your CB with an amplifier, than I would consider using a heavier duty antenna with the amperage capability of a Wilson a must. The best CB antenna from a physics point is an 8 foot whip, mounted in the center of your steel roof structure.
OK, here is an offer for Viper owners coming to the VOI....first Viper owner that shows up with an 8' stainless steel whip bolted to the top of his roof gets dinner at the best steakhouse of his choosing in Salt Lake on me!!!! It would be worth it to see that!!!
Good luck with your choice,
George
