not going to happen
MityVac = good for brakes.
Cheap-o pump = good for tranny/diff fluid.
I use on the the $9 pumps from Meijer/WalMart/auto parts store.
The orange/red one with a couple of feet of clear tubing.
Works great, and I don't have to scour some other kind of fluid out of it after each use.
Minor detail about the tranny fluid that gravity does not cover. Ya can't pour the new oil back in because you don't have that kind of access to the fill plug as the tranny is wedged up in the tunnel.
I use my Mityvac system for:
-> Brake and clutch bleeding
-> Power steering fluid changes
-> Filling the tranny
-> Differential fluid draining and filling
-> Cooling system fluid draining (fascia bottle if you don't want to pull the fascia)
-> And on my F350 filling the transfer case
If you want to see what kind of setup I use for each app and what Mityvac stuff I use PM me. I have pics of all of the stuff I use.
For brakes I still use a pump that I've used virtually all of my life --- my right foot.
