I left my key turned on for a few days and of course the battery was completely dead. Is there an easier way to slow charge the battery(with my charger) than REMOVING the rear wheel and liner like the manual advises?
Just open your hood and look for the post with the plastic cap (drivers side). Remove the cap. This is the (+ positive conection) . Hook your (- ground) cable to any suitible location.
yes,open the hood and on the driver side,close by the brake booster you will see a plastic red cap.
remove the cap,that's the + side, connect the + lead of your charger there and the - lead to any ground .
They are perfectly fine for charging. No Problem. Sometime down the road though, you might want to pull your rear wheel, pop the panel and inspect the battery and connections. Vipers require optimum current voltage to run properly. Don't forget to check for corosion in the tray.
