Just look at the dyno torque curves; Roe 800+rwtq at 2,000rpm. Stock, TT and Paxton are the same - about 200rwtq at 2,000rpm.
It was mentioned that shift point is better at peak? The Roe makes peak around 5,000rpm and loses maybe 45hp at 5800rpm. Not much loss compared to shifting.
A flat powercurve prodeces best/optimium power and a perfect example is the Roe torque curve which is nearly flat from 2,000rpm.
Set up properly at max, the Paxton and TT's will definitely show higher peak numbers, but actual driving and racing is where the Roe shines. It's the only forced induction system that makes full boost at 2,000rpm. Normally the positive displacement type of supercharger (like a GMC12-71 Blower) is undriveable and that's where Sean Roe's genius came into play with his power valve allowing the bypass so that we can drive with less than full boost, when we wish.
I like all forced induction systems, but I prefer the Roe for my driving style. If I wanted another 150rwhp, I can just put a Nitrous Bottle into the trunk. Haven't ever used it, and don't own a good set of slicks. I also have no plans to face over 150mph at this time so I will maybe never hookup the Nitrous, but it is impressive looking under the hood. If I wanted to post big numbers it would only take 200hp jets to post 1,000rwhp/1100rwtq with the rwtq being at 2,000rpm, but who cares and who could use it?
Ted
I think that graph confirms what's been said is the advantage for the Roe. My car makes over 600 ft pounds at 2000 rpms and holds it all the way to red line.I started my paxton dyno pull at about 2,200 and hit it. By the time it hit 2,300 I hat 450rwtq, and peaked at 605rwtq.
Do you have a similar graph to put up so we can compare side by side?I think that graph confirms what's been said is the advantage for the Roe. My car makes over 600 ft pounds at 2000 rpms and holds it all the way to red line.
Don't get me wrong though. Those are still great numbers.
I have one at home (I am at work). It is a line graph though, not a numerical data sheet as the one above.Do you have a similar graph to put up so we can compare side by side?
You don't mention anything about tires or car prep but all things being equal, if you're as good a driver as you state, you shouldn't have any problem seeing 130 plus.
Nice graph BaddazzV8
Most stock Vipers have around 440 rwhp stock. Do Z06's have a lower power loss thru the tranny than Vipers? Is 470 rwhp normal for stock Z06's?Ok this does not make sense, I have own both c6 zo6 with a pro-charger. Now I have a 2006 srt coupe that’s getting a blower ASAP.
My Z06 ran 11.44 @ 126 stock a 1.8 60ft and made 470 rwhp
After blower install it ran 10.78 @ 131 with a 1.6 60ft and made 587 rwhp on 4.5 pounds.
I want to see 130 plus out of my viper or I’m going to be pissed.
Not to boast but I can drive my ass off and I’m no lightweight jockey either.
I have an 8 lb pulley on there right now and my tune is limited by the fuel system. I am hitting 8-9#s on my in-car boost gauge under WOT but I am not sure how accurate it is. I plan to upgrade to a dual fuel pump system and a 10# pulley later on.Thanks, and how much boost are you running? I think you and I having similar numbers would be a good race to tell the outcome of this race, but there's no way I'm getting out to St. Louis, and I doubt you're coming out to Omaha anytime soon, haha. I'd love to dyno back to back with you on the same dyno and then race to see exactly where we stack up.
yes that was average last year.Most stock Vipers have around 440 rwhp stock. Do Z06's have a lower power loss thru the tranny than Vipers? Is 470 rwhp normal for stock Z06's?
I don't see myself making it to Omaha either. You should consider coming here though for a Joe Donovan (PBJ Performance) tune on your car.
