CROM
Ok, I took off the lower shield that covers the bottom half of the flywheel and this fell out. My assumption was correct that something was rubbing against the flywheel. Please note that the ruler is in Centimeters, so this thing is 2 Centimeters long and about 1 Centimeter Wide. This appears to be some type of alignment guide pin. It came from the flywheel area. Any clues? The car no longer makes that nasty noise, this was rubbing against the flywheel and shield causing that nasty sound. And if you know what this is, do I need to pull some stuff apart and replace it or am I OK leaving it as is????
Thanks for all your help guys.
