S&B filters and air box clips
SuperSaiks
I've read countless times how when using K&N air filters the air box clips have a tendancy to pop off is that the case only for K&N...because they are a very tight fit.
I am thinking of using S&B air filters they apparently fit perfectly... so does this mean the clips won't pop off?????
-FROG-
Austin, Texas
You can kinda tell when the pressure is a little different. If it locks down properly and feels really secure, you'll probably be ok. Drive around the block a few times and let the engine area heat up a bit, so the plastic can expand a little and listen to hear if it pops off. Just my .02
ruckdr
Renton, WA USA
I have S&B filters, and have never lost (pop off) a clip.
If you need to replace a clip, they are
GM (Chevy) Part No.: 25043286
Later,
tractor1996
