Sourcing Obsolete Parts For Gen I and Gen II Vipers
93rt10
Little plastic square trim pieces that guide the tops scissor clips into the gen 1 sportsbar!!!!!!!!!! They get damaged easily and as far as I know there are no replacement pieces.
Fatboy 18
Surrey, United Kingdom
Just a suggestion, but to save scrolling through the pages, would it be possible to have a list of the alternative parts on some kind of spread sheet with a part number and possible supplier?
DJ'sviper
Fuzzy paint, I replaced the alarm ignition. I think I have the old one but don't know if it can be fixed. Clippers. Thanks for helping out.
Tom F&L GoR
Wappingers Falls
Gen 1 and Gen 2 fog lights are available as Citroen D2 parts. Remove the plastic back and the Bosch glass body has a sticker with a part number: 0 305 403 001 Google it and you may find my new best buddy Sylvain on French eBay. He sells them for 30 Euro (~$45) plus shipping. I bought two and with international shipping paid a total of $140, came from Paris in 8 calendar days. Good luck.
Tom F&L GoR
Wappingers Falls
OK, was fooled by parts book image and these fogs are for Gen 1 only. But I encourage anyone to look behind the plastic back and search for a Bosch part number - might help to locate your part.
DJ'sviper
Air Conditioning, for Gen I. Fuzzy paint matching interior grey.
Dan Cragin
LA, CA
Viper parts are getting harder and harder to get. Many parts are are not longer available or on backorder. Viper front brake rotors have been backordered for 5 months, some suspension parts for 03-10 Vipers are no longer available and most all the Gen 1 stuff is no longer made. I was told (not confirmed) that when Dodge went BK all the parts providers were not paid, so they stopped making parts. When Dodge reorganized they had to find new vendors or just drop some of the parts all together.
aloushi
little plastic pieces that cover the screws on the inside of the removeable hard top. They pop in and out of place to access screws.
Dan Cragin
LA, CA
Brake and clutch pedal pads are no longer available for the 1992-2002 Models. Any advice?
Dan Cragin
LA, CA
You can use the earlier part numbers. They work just fine.
Needed 1998 viper gts electonic entry modul part number 4848832ag is the new part number can use 4848832ae, af or ac
This part is currently shipping from Mopar under the newest early Gen II part number (5015148AC) and includes two new key fobs matched up to the receiver.
Looking for GEN 2 passenger air bag cover.
This is integrated into the airbag module itself.
Dan Cragin
LA, CA
I am finding Gen 1 parts harder and harder to get. I currently have 1994 Viper in the shop with a bad fuel gauge sending unit (gas gauge does not work). The sending unit is no longer available new and is only serviced with the fuel pump. The fuel pump is a $1300 part from the dealer and about $700 if you can still find them direct from Carter.
Does anyone know if this sending unit is interchangeable with another model? The pump is very close to what was used in Dodge trucks in the late 80's and early 90's.
Any help would be appreciated!
Phun70
Urbandale, Iowa
Not sure on that. Can try to check around though. I had to replace my fuel pump module a while back, and now I wish I had kept the sending unit off the old one. I would have given it to you.
Goatman
Houston, Texas
It would be nice to have an update for this. Just to let us know what stage we are at with getting these parts. Maybe even a compiled list at the start of the thread.
Goatman
Houston, Texas
Hello VCA Officials/Moderators,
Can someone give some sort of update on this. I am not the only Gen 1/2 owner out here asking questions. I feel its your professional responsibility to do so since you purchased all the tooling.
ViperGTS
FYI: Jeff, one of my friends, started this thread, but he is "out"...a lot of good people left ...:eater:
