DrTaco
Ok, here we go.
1)Battery died for KNOWN reasons while getting gas at a BP--->Jumped, taken home and replaced w/ new Diehard Gold. Started/idled for about 15 min w/o issue.
2) First drive under load after replacing battery. Got about 2 minutes down the road and the car just died, I mean..no indications/noises, just turned off and I coasted to a stop.
3) Would attempt to turn over but will not start after several attempts. While attempting to start, noticed oil light on. Checked oil level at roadside and found it LOW (as in, at the "add 2 quarts level"). No leaks, drips, puddles anywhere. Added 2 quarts at roadside and oil level back to normal, and at a little above safe level.
4) Towed home. Still wont start, just will turn over. I hear the buzzing of my fuel pump system during startup and oil level is still normal, perfect color. As I attempt to start her the oil pressure DOES still rise as I make each attempt after one another. Lights/stereo working fine.
5) ***? Cam sensor, crank sensor? Bad BP gas? When I changed the battery I used one of those cigarette plugs with a 9v to save settings. Fob still locked/unlocked doors after battery change. Dont think I need to disconnect the + battery and ground it, do I?
Looking for suggestions on where to start
I have NOT pulled a plug yet, nor have I checked fuses. Any idea which ones to start with?
Thanks in advance while I wait for Tator to return call, mods in sig. I have a VEC, but as I understand, it will not come into play during startups
Mark
Mark
