rcl4668
Mark -- thanks for posting the numbers; when you post the dyno results for the car with the Belanger system, would it be possible to quantify how much hp and torque difference the ECU produces?
/Rich
/Rich
/Rich
A part number would be helpful too.
If I use the numbers we have from the Belanger only cars then see the difference you should get an idea of the benefits beyond what I have described above.
I have a PN but there is no such thing in existence yet so it won't do you any good right now. When they start producing the real deal for sale I will have that number verified for you all along with the suggested pricing.
Mark, does the new controller allow the revs to hit 6750, or 6500? My ACR hits 6250 stock.The added top end is from the extra 500 RPM allowed with the controller.
Mark --
Just so I am understanding you, does this mean that you will be taking a car with the Belanger setup, dynoing it without the Mopar ECU and then dynoing the same car again after the ECU install? Thanks.
/Rich
Either way, 250 extra RPM is great, especially for track use! That combined with the extra area under the curve is wonderful. I'd really wanted a few more revs - a standalone is looking less attractive now.
I have PBox logs of my car hitting 90 mph in 1st, and 163 in 4th. Based on the car's gearing and tire sizes, that indicates a 6250 RPM rev limit to me. Though I have had cars which read incorrectly in the past...
I have PBox logs of my car hitting 90 mph in 2nd, and 163 in 4th. Based on the car's gearing and tire sizes, that indicates a 6250 RPM rev limit to me. Though I have had cars which read incorrectly in the past...
Bob,
The new Mustang dyno software is using a correction factor of 1.10 and I have actually used the same numbers as Arrow does and we have almost identical out comes. This is the real reason we have been selected to help test this final product. That is why there is not an apples to apples comparison from the first set of headers or any of our S/C cars for that matter to the new software and correction factors. The new software converts to real ASE rear wheel numbers and then the factor we use per Arrow is 1.1, Hope I did not just cloud the answer worse...
The A/F is good at the 13.0 and I have just been told that the reason for the 12's after 4500 rpm is that there is a enrichment timer for the cooling of the pistons and exhaust valves after 12 seconds of WOT. This being said if I could have known this and did the dyno from a roll at 4500 rpm to WOT up to 6500 the HP increase would be substantially better.
I have another project in the works right now that we may be able to ADD on top of all this if it is approved but that's all I can say right now.
Bob,
That is my car and it had all the goodies put on it....MGW shifter, motor mounts....the works...Bob
Hi Bob. Congrats! Enjoy.
Best,
Bob
Personally I was disappointed in the numbers, maybe others were expecting more also? MHO
You have to admit though the torque curve is awesome and you really FEEL that when you are driving the most of the time.
Can't admit it until I experience it. When should I send my car for the free Mopar PCM so I can experience it for myself ?
I am impressed with the dyno graph's Mark (especially in the mid-range). I think now we will need an actual cost, plus more feedback from owners that are driving the cars, to get more discussion. I think the topic was beat to death before you actually received the unit...explaining the lack of discussion now.
The worse part about the hesitation is when you are heel and toeing, trying to blip it while you are downshifting. By the time the engine rpms catch up, you are already in the gear and the clutch is out!
