mjorgensen Woodhouse
PCM is in the same location and will not be hard to swap BUT the dealer has to do the install because of tool and Chrysler internet hookups are used to calibrate the T.B and initialize the PCM to the VIN.
will it stop the "check engine" light from recurring with Belanger headers?
Most of us (regular track guys) run 100 octane at the track on warm days - so no issue here.
On the street, Torco sells a very good octane booster that I use in my Paxton car on hot days. Wouldn't take much Torco to move the octane from 91 to 93 and 100 octane unleaded is also available locally on the street.
The NOS off road brand of Octane booster works well and is available at most auto parts stores.
"the dealer has to do the install because of tool and Chrysler internet hookups are used to calibrate the T.B and initialize the PCM to the VIN."
I wonder why we can't swap the computers ourselves? This is almost a deal breaker - and should be simple. This solves all of the issues, Mopar Computer at the track, OE computer on the street.
Perhaps Mark can help / explain this to the computer weenies.....
I hate to see everyone (including myself) throw out the words "deal breaker", especially with how hard Mopar has worked to bring something to market and at a reasonable cost. I think Mark would have to specify whether the first-time installation requires the dealer installation, or if every installation requires it.
Since the TB is controlled electronically, the dealer has to calibrate it, which makes sense, since I'm sure every car is different. 0% open throttle has to be programmed (blades closed)for that ECU on that car, as well as 100% open (WOT), for the ECU to accurately control airflow. However, what happens if the factory computer is shut down at maybe 1 or 2 % open (idle), then switched to the Mopar ECU that thinks it's at 0% on start-up or at 5% on startup. Will this issue compound itself over the course of multiple ECU switches, until the car is starting with the TB's wide open? Or does the car always shut down at 0% open? I'd go nuts if I had to think about it.
Mark J, we all like to fuss about small things here and there, but in the end, there will be people that have to compromise on octane rating/installation/price, etc. We all can't "have our cake and eat it too". Thanks for working with Mopar and SRT to bring this ECU to existence. I'm positive it will sell!![]()
Mark, thanks for all the info. If you have a chance, can you ask the guys about high altitude application and octane requirements at 6k ft? Normally at high altitude, one can decrease the octane requirement 1-2 points with the same effect as running 93 at or around sea level.
Great question SSGViper as the highest I can get here in Utah is 91 and I'm at 6K+ feet![]()
What is the effect on the warranty? Since the dealer has to install the PCM the dealer and Dodge will know of the change. Also, since its for off-road use will the dealers even do this swap? Thanks
So Mark does that mean that all of us track junkies can mostly count on you for our problems if the failure of whatever part on the car is not due to track use/abuse specifically?Some dealers will have a problem for sure and you could run into warranty issues but if the part does not cause the failure they will still need to honor your warranty. There are dealers out there though that will have no part of this I'm sure.
Mark,
If there is no torque management why does my car run slower with the nitrous than without? Its fine on the dyno and good through most of one gear and then the nitrous does strange things?? What are your thoughts? Thank you for your help.
