Dimitrios
what do i need to hook my laptop to my VEC2? anyone have pics of what i need? also where do i buy this from?
thanks
DK
thanks
DK
and play solitaire as I drive down the road.
You can also modify the rubber grommet on the driver's side door (open the door and look for the wiring harness that holds the speaker and door wiring). You can notch the grommet and fit a 9-pin serial post through there w/o issue.
JD
Tony,
That looks great for a permanent mount. My cable is the car for 15 minutes at a crack and then out. Nobody has ever seen it but us. If I'm doing more than a couple of runs at different times, I'll coil it up and put it between the VEC2 and the cowl.....otherwise it's behind the seat in the pocket with my OBDII reader. 99% of the time, I got a passenger in the seat next to me, not a computer
Steve
