Whats highest octane we can use on a Viper?
BACKNBLACK
NY
Just curious.I have a place to get CAM2 106 octane. How safe is it, do we need to mix with lower octane?? If used straight up, can you damage valves??
Snake Bitten
Southern Kalifornia
Leaded fuel, used straight up, will foul your O2 sensors, clog your cats...And would be a total waste of money, unless you have power adders that would require additional octane ratings to prevent detonation...can't see any damage to your valves...
I have found 93 Octane to be about perfect for a relatively stock viper...
SUN RA KAT
Guest
I have VEC2 cards for 91, 93, 94, & 100 octane unleaded gas. I found the 94 octane gas with the 94 octane VEC2 card to be a noticable improvement over 93 octane with the 93 octane card. I go to Sunoco for 94 octane.
Viper Days at Mid Ohio Sports Car Course will have unleaded 105 octane...
Warren S
L.A. (So. Bay), CA
I agree with Gerald. If it's leaded, don't run it in your Viper! It will do more harm than good. Then there comes a point where too much octane w/o the necessary higher compression ratio will lose, not gain hp. However, that CAM2 106 should be perfect for vintage muscle cars, say, your '70 440-6 Cuda.
93 octane or 94 Sunoco should do fine. We only have the crappy 91 here in the left coast.
:cool:
joe117
Maryland, USA
I'd say don't use leaded gas such as Cam2. I don't think it's worth the possible damage to the O2 sensor and the cats.
However, I wonder what the limit is as far as leaded gas. Will 6 gallons put in for the drags, one weekend a month, do any damage? I don't know. I'd steer clear untill I found out.
GaryA
USA
I run 93 octane on a 843 rwhp supercharged Viper and it runs GREAT!!
pauls
Akron, Oh USA
Over octane is a waste of money. Your computer can only advance the timing so far.(Even with a VEC 2) I've tried VP unleaded 103 and I think it slowed the car down. It's a black art, how octane and gas is formulated. Cylinder pressure, speed of flame travel and many other variables all play a role. The majority of Vipers (NA) run very mild compression. I don't think race gas has any effect.
