wheel guys!! whats the largest rear lip you can fit on a 20" rear
1bad540
having custom 3 piece wheels made and there telling me 3" is the fattest I can go in the rear? without rubbing, any truth to this?? Thanks guys pics to come soon!!
Jance GTS
Oklahoma City, Oklahoma
I have a Gen 2 with Gen 3 brakes and 3" is about all I could get with my 20's. I wanted a little more but I wanted bigger brakes so I had to just get all I could. I don't see it being much different on a Gen 3.
1bad540
Hmm i see some iforged and the rears look bigger. I could be wrong. Anyone else w 20s and a bigger than 3" rear lip
XSTAR_007
I'd say they are correct. I thought mine were 3" and just measured and they are actually closer to 3 & 1/4" in the rear. They are extremely close to rubbing and my shop told me they actually may have a slight rub on occasion when I was adjusting my coilovers last week.
1bad540
Thanks guys, I went to check out my newly finished custom 3 piece and I thought they were screwing with me that only 3" would fit. Was really hoping 4", but if they'll rub I'll stick with the 3's. Thanks a lot guys puts my mind at ease after dropping some serious coin on new wheels. Hopefully Monday I'll post pics!!!
martyb
IL
I have seen a gen 2 with about a 5" lip, it was a while ago at SVS's old shop here in Chicago. I wanted to say they were Iforged but I could be wrong. It was a yellow RT/10.
roller
North Lake, WI
Not sure where you are taking this measurement from, but my Iforged 20" wheels measure 3.5" from the inside of the outer piece to the edge which is probably 4" from the bolted joint surface.
Frank
AbsolutHank
Odenton, MD
Frank
You have a B/W GTS in your avatar? Is this the car the iforged wheels are on?
AbsolutHank
Odenton, MD
Offsets are a little different between a SRT-10 car, but more importantly, the small Gen II rear brakes will allow up to a 5" lip. That's the main difference between generations and wheel fitments.
ssjcreeper
Ohio
Looks like 3.5" on my set of ADV1 Concaves.
Nine Ball
Houston, TX
Gen 1-2 cars can get a deeper lip on the back, because of the puny brakes. Gen 3-5 cars usually have a 3.0 rear lip, unless the wheel is one of those "Super Deep" concave forgings. Then it can get 3.5-4.0 depending on the brand.
1bad540
Thanks nine ball, the 360 forged wheels u had on your vert had 3" rear lips?? Thanks for the input,,!
XSTAR_007
I have 360 Spec 5's, measured them earlier today when I posted and they are approx 3 1/4" lips. Which style did you go with?
[/QUOTE]
Green viper 1
[/QUOTE]
I love those wheels this car looks awesome
1bad540
[/QUOTE]
Thanks xstar, I was thinking of pming you. Yours look way deeper than 3 ", I went with a custom build 3 piece with arp bolts powder coated clear they are basically 360 straight 5's tho. I did 19-20. Hopefully ill have them installed today!!!! Will post some pics.
XSTAR_007
Are these 19/20 or 20/20
Thanks for the compliment. It's a 20/20 set-up. I love the look, but do wish I had more rubber on the front at times & if the roads are bad.
I've never regretted my decision and doubt you will either. Look forward to seeing them on your car!
Rahn
1bad540
Well I have the rears on, fr tires should be in today. Hopefully some pics later!!
tractor1996
