Since there has been a lot of talk about these cheap low profile jacks, I decided to take some pics and post how I raise my ride up in the air. It takes me about 5 minutes to do this. in the past, it would take me about 20-30 minutes to get the car in the air by driving on boards and then using the stock jack to raise the car up and then use the cheap autozone jack to get it up. It was time consuming and a big pain in the butt to do! No more!!I spent about $300 for the two aluminum jacks.
below are my two trusty jacks. They are awesome!
As you can see my car sits about 3.5 inches off the ground.
the jacks stand close to about 4" off the floor. As you can tell, they are still to high to go under my Viper
My viper sits too low even for these low profile jacks!
I take one of the jacks and slide it under the rear frame rails. Note, I just jack the car up enough to lift the car about 1-2 inches off the ground..You don't want to completely lift the car off the ground from that part of the rail. It's weak and could have bad effects. I just lift it enough to give me space to put the 2nd jack on the jacking point on the rear side sill.
DO NOT LIFT THE CAR TOTALLY OFF THE GROUND! JUST ENOUGH TO RAISE IT A TAD BIT.
Now I have enough room to slide the jack under the rear jacking points
once the rear of the car is jacked up from the jacking point along the side of the viper, I take the other jack and race over to lift the front up since I now have enough clearance.
Once I lift the front up, I can now remove the rear jack from the side and put it on the other side of the front jacking point to totally lift the front of the car up with out damage!
Notice the rear is now lifted up off the rear jack.
to give you an idea, how low the car sits now, you could stick all five fingers between the fender and the wheel in the past. Now I can barely get two fingers in.
Now for all of you that like to take off your suspension or springs, this tool is a must have. It's a hydraulice spring compressor and it's awesome and safe!
And for us poor garage owning people that don't have clean floors that you can eat off of, I'm sure every once in a while you see coach roaches or bugs in your garage. This is the best stuff to use to kill them!
