2004 engine swap for a 2006
It Bytes
Does anyone know what difficulties I would run into swapping a 2005 or 2006 engine into my 2004? Engine harness and computer would come with the new engine. Thanks
Fort Lauderdale, Florida.
I've done several of them- depending on the year you may (or may not) have to extend the factory crankshaft position sensor wire. You can extend your factory harness, just not the sensor wire.
Should be straight forward.
Regards,
Doug
I
It Bytes
What I have found is the connector from the Engine Harness C104 and the Main Harness are different. The 2004 main harness has 14 wires and the 2005/6 has 16 wires, two rows of 7 and an extra wire on each side. Any idea what the extra wires go to or how to deal with the connectors being different?
Slc341n
