Y2K5SRT
So today I brought my GTS in for A/C work (4th time is a charm). After sitting in the customer service lounge for a little over an hour, they still hadn't started working on my car (typical for appointments at this dealership). I wandered out to see when they might get started. A few minutes later they drove the car into a service bay. Where it sat, untouched, for another half hour. I finally hear the rumble of it starting up and decided to check it out. Glad I did!
They had opened the hood to look in and decided it needed to be moved to a different bay to go on a lift. They put the hood partway down - just the back and not the front. They literally put the car in reverse when I ran behind it and yelled "DON'T MOVE IT!" Here is a lesson for you newer owners and inexperienced dealerships: When the Viper hood is open in the front (past the latch) and the back is down, the back part of the fender is literally touching the tire. Crank the wheel either way in this position and you will damage the fender(s)! I remember one of the folks posting here that they did that when moving the car from the wash bay to the vacuums and snapped a chunk off of the fender when they turned the wheel while it was moving. I pointed this out to the Viper tech and the driver and they both looked like deer in headlights. They apologized profusely and thanked me endlessly.
Oh yeah, and the A/C still isn't fixed. They suspect a slow leak and ordered two hoses for it - the only thing in the system that hasn't been replaced except for the control knobs!
Chris
Chris
